s14 compact rally car
Re: s14 compact rally car
Postby abmass » Tue Feb 09, 2010 6:41 pm
some one stole my name
abmass
Postby abmass » Tue Feb 09, 2010 8:15 pm
not sure why but if you click on the photo it lets you go in to my photobucket site :? ah well theres loads of pics of the bm in there
Mod'father added:
Looks like you clicked the `thumbnail' option rather than the `full size option'
Hope you dont mind but i've added to your post so you can click edit and see what code you need:
8)
abmass
Postby is-si » Tue Feb 09, 2010 9:54 pm
Getting there... 8)
Engine looks almost built and nearly time for ancillaries etc 8)
I've 2 Questions.......
1, What do have proposed for the exhaust manifold?
2, Are you going to run a swirl pot?
J
Postby abmass » Wed Feb 10, 2010 7:41 pm
abmass
Postby abmass » Wed Feb 10, 2010 7:58 pm
abmass
Postby abmass » Wed Feb 10, 2010 8:08 pm
is-si wrote:Getting there... 8)
J
not sure about manifold yet i will have to get one made up unless you no something i dont :wink: and yes i will be runing a swirl pot, need to get a new mounting plate made up for the dry sump pump and sus out the belts for the water pump and alternater :?
abmass
Postby abmass » Wed Feb 10, 2010 8:10 pm
abmass
Postby is-si » Wed Feb 10, 2010 8:35 pm
Brill, Photos tell the story nicely 8)
I havent an answer for a RHD manifold, it looks like the tricky/specialist bit!
I ask about the swirl pot because i believe there is an issue with the E36 tank if you sometimes want to run it low on fuel.
Will you pull fuel out to the surge pot with a low pressure pump perhaps modifying the pick-up?
I'm curious as its a hurdle we will have to cross in time.
Thanks 8)
J
Postby abmass » Sat Feb 20, 2010 2:43 pm
just on the way up to get the car ready to move to its new home at ab motorsports new work shop i should be able to crack on and get it finished of then :D
abmass
Postby mef » Thu Jan 09, 2014 5:33 pm
I gather this is the shell and engine parts in the for sale section?
Whats happened to it in the last 4 years, why are you braking it up?
free bump up!
martin
Users browsing this forum: No registered users and 5 guests
