s14 compact rally car
Re: s14 compact rally car
Postby abmass » Wed Aug 26, 2009 7:50 pm
is-si wrote:Looks fantastic Steve, those front brakes look . . . . Big, to say the least 8)
2.5's s14's with Ram air sound the best - it will sound as good as it look 8) :D
The wheels fill the front arches, presuming you are on a 8" rim what offset have do you have?
the rims are 8" i think that the offset is 0 i will check and let you no
some one stole my name
abmass
Postby is-si » Wed Aug 26, 2009 9:37 pm
Thanks Steve 8)
Postby abmass » Fri Aug 28, 2009 6:36 pm
more work done today lights and flashers working (thanks neal) made the panel for the stack dash and the fuse boerd etc its starting to look like a car now :D :D i was told yesterday that i did not need to use verniea pulleys on the cams :? any thoughts on this. will take some pics off progress
tomorrow
abmass
Postby bruvs1 » Fri Aug 28, 2009 7:28 pm
two options steve, file holes and re-dowel, like our first attempt which worked.
http://www.bruvsmotorworks.co.uk/Gallery/s14acw.jpg or second attempt no dowel, still slotted wheels but machine the end of a standard cam and use it as a clamping plate on the front of the wheels :wink:
Postby is-si » Fri Aug 28, 2009 10:17 pm
as bro' says, its common to elongate/slot the holes slightly and then clamp up with the 6 bolts with the dowel removed.
However on our engine, the nose for the rotor arm (If you are still using it) clamps the sprocket to the exhaust cam, on the inlet cam (to settle my nerves) we chopped the end of an old cam off, then after doing a drawing (at work :x ) , had a clamping plate turned >
These are working fine on our engine that does 8k. :)
Edit: dont forget a new set of locking tabs that go under the bolt heads (part no. 11311305070)
First time round we re-dowelled the cams but apparently this is ott.
Postby abmass » Tue Sep 01, 2009 5:15 pm
thanks for the advice guys :D a few more pics of progress, the rest off the engine bits came from the states today cams, rods, valve springs e.t.c so will be giving them all to the man tomorow wiring is a f 65£"$$&^^ing nightmare (didnt help that me and neal were pissed all weekend :oops: are well it had to be done :D
abmass
Postby thedoc » Tue Sep 01, 2009 6:04 pm
Yes well it had to be done indeed,have we ever been in any other state when I have been down!!
Glad to say the wiring was starting to make progress from the nightmare which faced me at the start of the week. At least the germans opt to use the same colour of wires for each job throughout the whole car unlike the Italians. Actually looking forward to finishing it, bit by bit.
Anyone know where we can get hold of good interconnecting relay holders?
Neil
thedoc
Postby Sunbmw » Tue Sep 01, 2009 11:32 pm
thedoc wrote:Yes well it had to be done indeed,have we ever been in any other state when I have been down!!
Neil
Here you go................
http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php
http://www.m3spares.com
http://www.ultimateid.co.uk
Sunbmw
Postby abmass » Tue Nov 24, 2009 7:55 pm
OH s**t help :? i may have made a big f#$#k up i think now that i have a small case diff (well 3 ) and i have the cage mounts going to the pick up points :oops: .if i fit a medium or large case diff will these be the same?????????????????????
abmass
Postby is-si » Tue Nov 24, 2009 8:04 pm
small (168) and medium (188) have the same fitment. Never had a large diff (210) but suspect they will differ
Postby abmass » Tue Dec 01, 2009 8:17 pm
i have been talking to a guy today who said that he would be able to make up a 2.2 lock to lock kit :shock: to fit a standard compact rack would any body else be intrested in one dont know how mucgh they will be yet i said i would see if there is any more intrest and get back to him
abmass
Postby bruvs1 » Tue Dec 01, 2009 9:24 pm
are you planning to use a power column or standard hydraulics?
Postby Ptrs14 » Wed Dec 02, 2009 12:28 pm
abmass wrote:i have been talking to a guy today who said that he would be able to make up a 2.2 lock to lock kit :shock: to fit a standard compact rack would any body else be intrested in one dont know how mucgh they will be yet i said i would see if there is any more intrest and get back to him
I would have an interest if this could be done for a LHD rack ??
Ptrs14
Postby sg_frost » Wed Dec 02, 2009 10:18 pm
I might be interested depending on cost
Could be worse, It could be my car with a problem!
sg_frost
Postby compact119 » Sun Dec 20, 2009 4:08 pm
also interested in the rack cost pending
I beg to diff-her
compact119
Users browsing this forum: No registered users and 5 guests
