6 or 8mm Fuel lines?
Postby mrfuzzyfelts » Thu Jan 10, 2013 2:45 pm
Just need to order the fuel lines for new car..
Was going to go 6mm but should i go 8mm?
Possible running M3 engine in the future so dont want to use 6 if there not up to the job!
Re: 6 or 8mm Fuel lines?
Postby GAJ1 » Thu Jan 10, 2013 7:40 pm
I think the Standard Connections to the inj piping are 8mm Anyway. AN-6 is 8mm inside Dia.
We bought some of this for our car but reckon to be safe you need 6-7M for feed & Return lines
http://www.ebay.co.uk/itm/280524340146? ... 1423.l2649
Postby Daishag » Fri Jan 11, 2013 12:50 am
8mm fuel lines mate !!!!!!!!!! also put a fuel swirl pot and high pressure pump in as well, use the std in tank fuel pump as a lift pump to the swirl pot as then theres no chance of fuel starvation on corners, its better to be safe than sorry !!!!!!!
Cheers Dave aka Daishag @ DSR Motorsport 07805835655
