E36 front bottom arm twisting
Postby keithr » Wed Jul 04, 2018 12:54 pm
Used my E36 M3 on the recent gravel Argyll Stages and o/s front bottom arm twisted along section from inner joint to hub pushing the wheel back in the arch. Had Meyle HD units fitted but must have taken a good knock and suppose weight of engine won't help. Positive is it didn't break just twisted.
Is there a stronger bottom arm available that does not have the cut outs along its length? Trying to avoid the cost of bespoke bottom arms.
keithr
Re: E36 front bottom arm twisting
Postby kmsrallying » Wed Jul 04, 2018 4:29 pm
Hi Keith R
I'm sure Garry Muir will be along in a second with the details of the arms the guys in Finland are making (rally Corsa Shop or something). I did the full SRC in 2016 with a compact and only had to replace one arm for the Galloway hills as the outer ball joint was showing some play.
I was told to use Lemforder parts by the original builder of my old car and had no issues.
I believe Lemforder is what BMW actually fit themselves.
My new car is going together using Lemforder parts.
I would accept I was probably not travelling as quickly as you :D but we had a few bumps and jumps along he way.
I'd certainly recommend Lemforder as was recommended to me.
Regards
The other Keith (S) :D
kmsrallying
Postby keithr » Thu Jul 05, 2018 8:31 am
Keith, I know about the bespoke arms that Marko makes for the E36 but plan was to try and use as many std parts as possible to keep costs down. I'll have a look at the Lemforder units. What model are you building?
keithr
Postby kmsrallying » Thu Jul 05, 2018 10:57 am
Another compact, using the alloy block 2.8 (cheap as chips)
I bought a caged shell through Garry from one of his mates up there.
Bit to do but i'm getting there...wish i'd just bought a complete car again :lol:
I made a series of bad decisions since 2016 (first one was selling the BM) but i'm back on track again....
I'll get it finished and logbooked this year do a few John Parker Forest test days if I can, then back out next year, possibly a limited programme pick a few events, then year after full SRC again
kmsrallying
Postby Overthelimit » Thu Jul 05, 2018 4:59 pm
We just use cheap bottom arms from ebay and treat them as a consumable.
They need a pretty good bash to bend them and as you say, they don't break, just bend a little, so at least you can keep going.
If you fit strengthened ones, is there a risk of the next weakest link breaking if you hit anything?
Bottom arms are easy and quick to change
Postby Garry.M » Sun Jul 08, 2018 10:10 am
I'm sure Chris Ransley said to only use Lemforder arms as well
