Castor and Camber Angles
Postby Bimsy » Fri Mar 16, 2018 6:28 pm
Hi All, Anyone out there could help? Looking for Front Castor and Camber angles for E36 Compact rally car, using Adjustable top mounts. Heard that camber should be around 1 degree negative? any opinions?
Thanks in advance :D
Re: Castor and Camber Angles
Postby Overthelimit » Sun Mar 18, 2018 5:06 pm
E36 Coupe. I use about 3 deg front and 2 deg rear on tarmac. About 1 degree each in the trees.
Feels OK, not much understeer issue.
The local BMW circuit race guys have what looks like about 5 degrees at each end!!!
Postby Bimsy » Sun Mar 18, 2018 5:44 pm
Cheers, I take it your talking about negative Camber? Any idea on the Caster angle?
Postby petsracing » Sun Mar 18, 2018 7:10 pm
For gravel the factory sport set up is perfect and is exactly the same as a mk2 escort gravel set up 3 degrees castor and 1.5 to 1.7 camber with a touch of toe in
petsracing
Postby Bimsy » Mon Mar 19, 2018 3:57 pm
Sorry guys I should have pointed out it is for Tarmac Rally not Gravel
Postby Overthelimit » Wed Mar 21, 2018 6:38 pm
Yes, negative camber.
I have E36 M3 top mounts swapped left to right and offset lower arm rear bushes which alter the castor.
I dont know how much they alter it though.
Postby mrfuzzyfelts » Tue Apr 03, 2018 11:25 am
2.5-3 on front Neg
1.5 on back i run
