Porsche brake conversion e36
Postby Lwhite21 » Mon Jan 11, 2016 10:16 am
Has anybody had any experience using Porsche Boxster brakes on an e36?
What discs can be used?
I'm looking at options for my compact rally car and need to fit brakes under 15" wheels
Lwhite21
Re: Porsche brake conversion e36
Postby martine30rally » Mon Jan 11, 2016 5:02 pm
Won't fit under 15 inch wheels they're meant for m3 discs. Best option would be standard 280mm discs and some wilwood narrow calipers, either 4 or 6 pot with a bracket made up to suit
martine30rally
Postby avtovaz » Thu Jan 21, 2016 9:38 pm
they will actually...
you just need the right 15" wheels
Россия лучше всех
факт
ENDA BMW tuning
avtovaz
Postby samdemange » Tue Feb 09, 2016 7:45 pm
made this for mine
with 300x22 discs ( e46 ) and rear 386 boxster calipers
and a home made adapter for them
16' rims just fit
add HP make you faster in straight line
lose weight make you faster every where
(colin chapman )
samdemange
Postby pets56 » Wed Oct 26, 2016 6:10 pm
But how you solved rear brakes. Also porche calibers?
pets56
Postby mrfuzzyfelts » Thu Oct 27, 2016 3:19 pm
Lotus Elise front calipers or VX220 front on the back :)
Postby pets56 » Thu Oct 27, 2016 6:13 pm
Okey. :D I belive they are same expensive than wilwood :D Now i have orig e36 s50b32 rear calibers, ferado 3500 bads disk is also s50b32 but i was make it smaller and make new caliber holes. Now i would like to put something cheap and 4spot calibers.
pets56
Postby greeny 751 » Sun Nov 27, 2016 3:04 pm
Which wheels go over the Porsche Brembos that you have fitted to the front?
greeny 751
