anti roll bar??
anti roll bar??
Postby CMJ motors » Wed Dec 09, 2015 10:45 pm
Hi, I've been speaking to a few people about this and I seem to be getting different answers so a few more opinions would be much appreciated,
front and rear roll bars on or off for the woods??????, running coil overs ! Bmw e36 compact
Thanks :D
CMJ motors
Re: anti roll bar??
Postby rally_rich » Thu Dec 10, 2015 1:10 pm
I have run my compact with just a standard 316 front anti roll bar in the forest. I personally don't think a rear anti roll bar will help on the loose. I have not tried without the front roll bar to compare but the car feels quite balanced and turns in very well so I think it is a good starting point.
Rich
rally_rich
Re: anti roll bar??
Postby CMJ motors » Thu Dec 10, 2015 10:17 pm
Well my 318 ti has rear roll bar already fitted and debating weather to take them off or leave them on!
CMJ motors
Re: anti roll bar??
Postby Garry.M » Thu Dec 10, 2015 11:16 pm
Z3 had the smallest front arb @22.5mm and they work up from there,,, think you'll find 23mm and 24mm on some of the saloon/coupes. Compact had 25.5 and 26mm iirc. I'd think removing the rear for gravel would be required to aid traction
Re: anti roll bar??
Postby CMJ motors » Wed Dec 16, 2015 2:16 pm
Thanks Gary. So you think running small z3 bar on the front would be a good start then! Going to remove the rear altogether !
CMJ motors
Re: anti roll bar??
Postby red325 » Sun Dec 20, 2015 8:12 pm
Really will depend upon your spring and damper set up.
Several years ago Geoff Jones (ex works driver and rather handy behind the wheel - see below clip) did a back to back gravel test in my E30 on Challenge spec suspension his view was that turn in was loads better with the front arb completely disconnected. It was all about allowing weight transfer onto the outside wheel. He is a far better driver that I will ever be so his advice was duly followed.
https://www.youtube.com/watch?v=7i1nuU6zCEc
red325
Re: anti roll bar??
Postby donald » Sun Dec 20, 2015 8:48 pm
I run my 130i on gravel with the front anti roll bar removed, have also done this on all my previous bmw's, e30 m3, e30 325i and 2002tii. Turn in is much better without it.
Have always left the standard rear in place, if you remove it you will need stiffer springs which won't help traction.
donald
