gaz golds
gaz golds
Postby compact119 » Wed Jul 15, 2015 10:40 pm
has anyone tried them ?
any feed back on service and how well they work along with reliability and strength ??
Jon
I beg to diff-her
compact119
Re: gaz golds
Postby mrfuzzyfelts » Thu Jul 16, 2015 2:58 pm
Dai shag uses them, think he is happy with them
Re: gaz golds
Postby lahondal » Tue Jul 21, 2015 1:28 pm
I have them in my compact.
Dont tried other brand but mine are awesome. Maybe a little bumpy but i think is because my spring selection, too hard...
Service is good, i bent a front strut and they were fast and cheap, 70pounds for changing the piston rod shipping from spain included.
Re: gaz golds
Postby compact119 » Tue Jul 21, 2015 9:23 pm
that sounds good, I like the service I have had so far with just sending an enquiry into them. how did you bend a piston, did you go off or heavy landing etc ?
all positive so far :D
I beg to diff-her
compact119
Re: gaz golds
Postby lahondal » Thu Jul 23, 2015 12:13 pm
No, i take too quick a corner and hit a guardrail sideways in fourth... :lol:
Re: gaz golds
Postby Garry.M » Thu Jul 23, 2015 7:43 pm
I used the Gaz gold kit on my compact cup race car,,,, they worked away on the circuit but I'd be worried about the stroke,,, not much droop if any for a rally car.
Avo do a good kit with a proper 40mm inverted monotube front strut and a coil over for the rear. They have the standard amount of damper stroke more suited to rallying in the UK
Re: gaz golds
Postby compact119 » Thu Jul 23, 2015 10:30 pm
found some more info on the avo kit and its out of my budget I'm afraid, I am still considering using what i have fitted to a few other compacts I have built in the past for other people and that's a bilstein B6 fixed platform struts and standard sport springs, these give a real nice feel to the car but obviously offer no adjustment. also comes in cheaper than the gaz kit
I beg to diff-her
compact119
Re: gaz golds
Postby Garry.M » Thu Jul 23, 2015 11:19 pm
Have you spoken with Phil @ PDL?
He did springs for the std platform as well as modify them for 2.25",,, worth a call
Re: gaz golds
Postby compact119 » Fri Jul 24, 2015 9:04 pm
I have called a few times a wile back and never got a answer with messages left but no response. I am tempted to make my own.
I beg to diff-her
compact119
Re: gaz golds
Postby bruvs1 » Fri Jul 31, 2015 9:37 am
Easy enough to do, and stronger than narrow rod gaz golds, get a set of 328 sport front legs , coilover the bodies, revalve the inserts with bilstein. Rears can also be sorted through them, be patient with them but they can be helpful, if they feel like it !!
Re: gaz golds
Postby compact119 » Sat Aug 01, 2015 9:30 am
That was my biggest concern, the strength of them. Don't think they would be unto the punishment of a road rally.
I beg to diff-her
compact119
