E30 Forest
E30 Forest
Postby madkiwi » Thu Jun 25, 2015 9:29 pm
I have a 4cyl e30 and the plan is to use it on tempest gravel in November.
I already have a pair of challenge inserts to go in and as I can't get any challenge springs I was wondering what poundage spring to go for up front when I change it to coil over.
Bulldog Cafe
North Lane
Aldershot
GU12 4SY
madkiwi
Re: E30 Forest
Postby Adam Gardner » Fri Jun 26, 2015 11:06 am
Hi I have ran an e30 318is as a road rally car for a while on 200lb 14" long springs. I had to go for longer springs as I was getting them coil bound on hard landings and rougher ground.
I felt the car handles well on these, I had a pair of challenge springs on originally and the car sat high and didn't turn in as well.
Re: E30 Forest
Postby madkiwi » Fri Jun 26, 2015 11:59 am
What did you run in the back.
Bulldog Cafe
North Lane
Aldershot
GU12 4SY
madkiwi
Re: E30 Forest
Postby Adam Gardner » Fri Jun 26, 2015 4:24 pm
Most of the challenge guys used to run standard 325i springs rather than the challenge eibachs.
I have changed between the two, I think the challenge springs are slightly stiffer, I tend to run those with two of the rubber pads below the springs for rough events but with no rubbers for tarmac to lower the car slightly.
We use a e30 touring rear spring on a compact to stiffen and raise the rear end slightly.
