Floor mounted pedal box - thoughts
Postby Garry.M » Sat Jun 29, 2013 7:26 pm
I've been thinking about fitting a floor mounted pedal box to help move the weight backwards in the car,, I realise I'll have to extend and lower the steering column along with doing something with the gear stick. Anyone on here fitted one or had experience's with fitting one to a compact?
Cheers, Garry
Re: Floor mounted pedal box - thoughts
Postby bruvs1 » Sat Jun 29, 2013 8:50 pm
Yep, yet to be tested in anger, but like the feel of the pedals, hasn't moved the driving position massively but feels like an improvement, got tilton clutch and brake pedal and made the accelerator ourselves.. bottles in the engine bay and on an adjustable plate, pics on the bruvs compact page p26
Postby Garry.M » Sat Jun 29, 2013 9:22 pm
I'm away for a look,,, what kind of $ was the pedal box then?,,, if you don't mind me asking!
Postby Garry.M » Sat Jun 29, 2013 10:41 pm
Found your pedal box online,,, how can the 3 pedal one be SO much more!?
Postby martine30rally » Sun Jun 30, 2013 11:10 am
Definitely feels like you can put more pressure on the pedals - also has the ability to make your legs ache a lot until your muscles get used to the opposite motion.
Was sitting in traffic the other day holding the clutch down and wanted to cry I was in so much pain!
Postby is-si » Mon Jul 01, 2013 7:26 pm
Some E36 steering columns are adjustable so you can use the base socket where they pass thro' the bulkhead. You can then set the height with 2 spacer washers at the top of the column under the instruments, a spacer behind the steering wheel boss then lengthens the column.
Postby Garry.M » Mon Jul 01, 2013 10:57 pm
Good idea!,,, I'll have a look in local scrappy for one :-)
Postby mef » Mon Jul 08, 2013 5:35 pm
Well it was OK in my first rally car, a Skoda Estelle! these type of pedals were standard!
