Escort turreted shocks on e30 rear
Postby kipsy » Mon Mar 25, 2013 9:42 am
Hi peeps, after breaking a shock on my e30 yesterday (bilstein challenge) I've read a few places that escort shocks fit. Is there any alterations to do or do they fit straight on and how do they perform- ie similar valving etc
Thanks kipsy
kipsy
Re: Escort turreted shocks on e30 rear
Postby alan1272 » Mon Mar 25, 2013 6:11 pm
have a look for avto's build thread, he's got them on his compact i think.
Postby avtovaz » Mon Mar 25, 2013 9:58 pm
yes i have with coil over conversion...
if you knock the bush out of your bmw shock and fit it intot he bottom of the escort one, itll just fit no probs
Postby kipsy » Mon Mar 25, 2013 10:03 pm
Thanks for reply- that's £100 saved then ;)
kipsy
Postby kipsy » Mon Mar 25, 2013 10:04 pm
kipsy
Postby kipsy » Mon Jul 01, 2013 9:58 am
Just realised I forgot to update this. They don't fit- they will rub the cv joint and there doesn't look like a lot of clearance to the shell as the e30 is quite thin and the escort shock is quite 'chunky'. Ah well cheers for the help peeps
kipsy
Postby Garry.M » Mon Jul 01, 2013 10:32 am
Can you not use the offset top mounts that move the rod backwards?
I discovered that as well while trialing an Avo 2-way rear damper on my compact . I'm kind of in the middle of helping design a new damper that clears the boot and doesn't foul the chassis. It's ok on a race car where the full droop isn't important.
