non power racks
Re: non power racks
Postby jonnysprinter » Tue Jul 21, 2009 7:36 pm
alan1272 wrote:i think that some early E30's came with a manual racks, might be worth a try? they'll be a bit long lock to lock probably.
I've got a manual E30 RHD quick rack on my donor vehicle. I think it's 3 turns lock to lock :wink:
Always look on the bright side of life :-)
Stay wuth her johnny - BMW E30 318iS
http://www.utilitywarehouse.org.uk/doyo ... ointheclub
jonnysprinter
Re: non power racks
Postby jonnysprinter » Tue Jul 21, 2009 8:01 pm
abmass wrote:started to change the steering coloum today for the corsa one it looks like its going to be a fairly simple conversion :? i will take some pics and keep you informed :D (ps what was with all the porn the other day :shock: )
Sounds a bit weird, but interesting. Looking forward to seeing photos :)
(looks like we've been spammed again by a porn site :roll: )
jonnysprinter
Re: non power racks
Postby is-si » Tue Sep 08, 2009 1:15 pm
Spotted this on another forum >
http://board.s14power.com/showthread.php?t=5786
Perhaps another rack possibility here, from another forum.
Rather than log-in, basically its a Z4 rack (that has a power column normally), its pictured next to an E30 m3 rack which is a similar fitment to an E36. Pinion splines are apparently different
The Z4 movement per revolution is 51mm, a 2.7 turn z3 rack is 53mm.
It looks a strong jobbie, or it may be a possible basis for some new machined internals :?:
Re: non power racks
Postby lahondal » Mon Jan 22, 2018 6:54 pm
is-si wrote:Theres a guy who does e30/e36 race/rally quick racks in several speeds in europe, i've had prices off him before i went to sellholm. They are all in bmw casings too so should be good and strong 8) .
If i have time later i'll dig out his name, he's called Roland ___(i think) - you may have come accross him. . . .make sure you are sitting down :lol: . Sellholm i'd guess do manual ones too.
Our 2.5 power rack has been well worth the money 8) bolts straight on, retaining the b-m/zf quality engineering.
At the moment im running a z3 rack with a steering quickener and althought it works fine, i have to drive with both hands in the wheel as the steering is a little hard, usable but very hard in my opinion.
Im thinking on fit a sellholm steering rack but the L2L spec is 2.4turns, and my current system have 1.8 turns L2L.
My times are super dependent on the steering quickeness, as I lose a lot of confidence in cars that have slow racks, and i have some fear of purchasing the sellholm unit and feel it as a downgrade in the end.
Do you think it worth the money over my current system?
